Early Model175 auxiliry hydraulic pump
21hunter
I'm the lucky? owner of an early 175 that has the flat bottom (506322M92)auxiliary hydraulic pump. The pump should be replaced but isn't available. What are my options? I have a front mounted pump on the tractor that I can use for the auxiliary hydraulics but I need this pump to run the multipower.
Thanks
Dave
Yes, but how do I mount it? Those pumps mount with the newer style mounting plates, mine mounts with a mounting pad on the bottom that is part of the pump body. What other parts do I need to make it work?
Thanks.
This is interesting, from the AGCO online parts book.
Page 342: (MULTI-POWER WITH LIVE P.T.O. AND AUXILIARY HYDRAULICS) (USED PRIOR TO TRACTOR SERIAL NUMBER 9A 15593).
506322M92 (B) Pump Assembly.
(B) Used Tractor Serial Number 644000339 To 9A 11664. For Repairs Order 517614M94., Pump Service Kit (See Page 345).
Page 345:
(SEE DEALER SERVICE BULLETINS, TRACTOR 68-15 AND 68-15A).
517614M94 Service Kit, Hydraulic Pump (Order 517614M95).
Pump Assembly (See Page 337).
Page 337:
HYDRAULIC PUMP 18 SPEED W/LIVE PTO& AUX. HYDRAULICS 8 SPEED IPTO & AUX. HYDRAULICS.
531607M91 Pump Assembly, Hydraulic
The service kit 517614M95 is a adaptor setup for the newer style pump. I could only find one service kit 517614M95 at TractorHouse.
I wonder if a salvage yard would have a complete newer style unit that would bolt in to my tractor? Of course I still might need to replace the Aux pump if it's bad.
(quoted from post at 08:49:38 04/30/17) I wonder if a salvage yard would have a complete newer style unit that would bolt in to my tractor? Of course I still might need to replace the Aux pump if it's bad.
There is bound to be a newer 3 point lift pump with a axillary pump that will bolt in place of the old style. Dieseltech here on the MF forum may know what pumps can be used to replace the old style like you have.
