TractorLinks.com
Show Parts for Model:
Need help to install bulb on new light
Cormiers Cove
04-20-2017 12:16:31
I bought a pair of these aftermarket lights. The bulbs came but not installed.
I loosened the screw from the clips but I cannot for the life of me get the cover off. It won't even budge.
I bet it's painted shut. I don't want to damage the light trying to open it.
Is there a trick to these?
Charles in Aus.
04-21-2017 15:40:48
 Re: Need help to install bulb on new light in reply to Cormiers Cove, 04-20-2017 12:16:31
The lights themselves are actually fairly good , at least the ones I bought were . The paint on the other hand is junk and will cause no end of trouble if you paint over it with your final colour .
Use paint stripper to weaken the paint at the joint then pry them apart gently . Once dismantled take every bit of paint off and re coat using a spray zinc primer .
ptfarmer
04-21-2017 14:35:14
What is the part number for the light?
Cormiers Cove
04-21-2017 13:41:14
Already did with an Exacto knife. Didn't work
Abnormal
04-21-2017 12:28:14
Might try running a blade around the edge of the rim. Shouldn't hurt it too much.
Cormiers Cove
04-21-2017 11:36:58
The seller on EBay from India sent me a message that they paint them after they are assembled.
Go figure! What a bunch of dummies. Sealed shut with paint. No way to open them to install a bulb without damaging the lights. Trying to break the pain seam and crack them open will result in damage.
Holy Smokes. I'm getting fed up with everything we buy these days. Doesn't matter what it is. Fridge, couch, fishing rod etc... Everything is junk!
Crazy Horse
04-21-2017 09:38:32
The question really is ...... "How many old tractor guys does it take to install a light bulb?" Answer (so far) ..... "None, it appears impossible."
fbh44
04-20-2017 17:54:23
Might be a rubber gasket in there, sealing itself shut.
miner09
04-20-2017 14:57:07
I would think after taking screw out it should just pull and off by looking at picture.
