oregonfarmer
My Perkins diesel has an oil pressure problem. I installed a new SW gauge directly to the block (no line) when the problem started. but it read same as old MF unit.
Here is how the gauge reads-cold startup 40 and in a few seconds it slowly falls to 0. In a few seconds it goes back to normal. The pressure may stay normal for a time and then repeats the up and down cycle. Engine RPM seems to make little difference.
I have flush the engine twice and new oil stays very clean now, but the oil pressure fluctuations persist. I started using 20-50 oil(used 30 before). The engine runs well and uses little oil. I keep using the tractor. Am I going to ruin it?
