We have a 1969 MF 175 diesel (LOVE it!). The other day I noticed a drip from the rear of the tra.ctor and it
was coming from one of the 4 bolts that hold the drawbar assembly to the rear of the tractor. I drained the
oil and removed the bolt. Well, one of the 4 bolt holes go all the way thru the casing, and the bolt was not
the correct one and hence the leak. Someone has 'farmer rigged' it years ago apparently with a rubber boot
and poly material, and my pulling the harrow jarred their fix loose. Is one of the holes meant to be a drain
hole? On ours, the threads are stepped, so the bottom threads are bigger than those up higher in the casing.
Is that normal or another of their 'fixes'? If not normal - any suggestions? Thanks!
