gregrweiss
New User
I inherited a 1963 Massey Ferguson 35 Utility with a MF 99 front end loader on it. The loader seems to be losing lifting power so I'm guessing it's either the hydraulic pump or the control valve.
According to the owner's manual, the MF 99 Loader has a lifting capacity of 2,300 lbs half height and 1,500 lbs at full height. Right now it's struggling to lift 850 lbs square bales at half height. The dump piston seems to have more power than the two lift cylinders so my first guess is the control valve either needs to be rebuilt or replaced.
I've replaced the hydraulic fluid and cleaned the fluid filter in the pump without any noticeable improvement.
Does anyone know if there is a kit available to rebuild the control valve? Likewise, does anyone know if there is a kit to rebuild the hydraulic pump? Any other suggestions are greatly appreciated.
Thanks!
Thanks!
