I have a 1967 Massey Ferguson 135 gas burner that at times is nearly impossible to shift without idling down until it nearly stalls. Most of the time (75%) it shifts smooth as silk at any rpm. It doesn't seem to matter if the tractor is hot or cold. I've also noticed that many times the gears don't seem to fully disengage when the clutch is fully depressed. With the tractor in neutral, the gears grind when trying to shift into first or reverse. The gears don't seem to be slowing because I can give it 10-15 seconds or more and the grinding is just as bad. Same as above, I can only shift if the tractor nearly stalls. Anyone know what is going on here?
