Injector Pressure
miner09
What is the Injector Pressure for a Perkins MF 35--1964. I checked old injectors today
and they were set at 1500 psi. My manual shows 2700 is this correct? It ran OK but I
replaced with new injectors and set new ones at 2700. Have not finished or started.
Thanks
Here's info from the "MF Technical Service Manual Form No. 1448 811 M1"
3 Cylinder Perkins Diesel: A3.152 Engine:
I'm sure others shall add their hands on experience:
I should have included, the Local Diesel Injection Shop, Dismantled, inspected,cleaned, assembled and all injectors were set at 1750 psi:
Code Indent Tag on Injectors was "DB" with .0152 orifice Diam.
3 Cylinder Perkins Diesel: AD3.152 Engine:
The AD3.153 is DIFFERENT than the A3.153
