MF 135 Throttle linkage
Levibooty
There are two rods that make the linkage. One goes from the throttle to the carb/gov lever and a shorter one back to the carb. Which rod goes to which hole? There are two holes in the lever, one at the top or end of the lever and one close to the shaft from out of the timing cover.
How about this:
Assuming this is the lever you mean... The top hole is for the short rod with the clevis that goes to the carb and the arm that kinda curls around is for the throttle lever with the springs.
