TractorLinks.com
Show Parts for Model:
Bleeding oil on MF135
Kalamazoo
03-20-2017 04:10:46
Just got done with a in tractor rebuild, and I'm getting ready to break it in.
Any way to bleed the oil before starting?
I was thinking of keeping the valve cover off and spark plugs out while turning the motor, will this work? I would like to see oil flow to the top end.
ptfarmer
03-20-2017 10:34:05
 Re: Bleeding oil on MF135 in reply to Kalamazoo, 03-20-2017 04:10:46
I always pack the oil pump with white lithium grease, it helps seal the oil pump so it can draw oil when its dry. If its a Perkins engine with a spin-on oil filter you can also fill the oil filter with oil so the oil pump doesn't have to fill the oil filter.
I made a oil primer system similar to this, but with sight glass so I don't push any air in after the oil (not my video, but it will give you an idea).
https://www.youtube.com/watch?v=thfTnYdeNz8
Kalamazoo
03-20-2017 08:38:47
Should I then see oil pump to the top end by turning the engine with the starter and valve cover off? I tried this and got nothing.
rockepg
03-20-2017 07:43:39
X2 on the lube. I use a mix of permatex assembly lube and moly grease. Slather it in there on everything that moves and you should be ok. Helps, a little, to poor a quart of oil over the rockers when you go to fill it up. Won't supply much but it does help until pump takes over.
Lost of track of how many auto and truck engines i built that way.
DavidP, South Wales
03-20-2017 05:48:32
Hi,
On a 'dry' engine it might need a little more than 10 to 15 seconds. Several bursts should be enough to send the oil to the top. Give it enough time to fill the rocker tube and work its way through. Always very reassuring when you put the cover back on that oil is definately getting there. You may have had something similar in the States to the 'Sellarc' grease guns that were sold in the UK in the early 60s. It consisted of a metal cylinder that would hold about 1 to 1.5 gals of grease. There was a fitting on the top to air pressurize the space on top of the grease to help force it through the gun and then refill when the pressure had dropped after use. I changed the gun fitting to fit Perkins oil pressure outlet and replaced the grease with oil. Using it to fill the oil galleries on a 'dry engine made life a lot easier. Lost count of the number of engines it was used on. Not a lot of work to make but great results.
DavidP, South Wales
Phil Tibbetts
03-20-2017 05:12:23
I always oil and grease everything up good while assembling, including pistons, rod and main bearings, rocker arm shafts Etc, Crank motor over for 10 or 15 seconds before starting. Never had any problems with this method. IMO
