265 action today
FinnMD
cheers, thought I'd post a pic from today with the 265 and 3 tons of potash and pelletized lime to go on the hay fields. Weather is perfect for this now in mid-atlantic area of US, freezing nights and daytime thaws allow fertilizer to get in soil cracks/fissures. Will also spread some red clover.
FinnMD, can you explain the lines running down from the front frame of the 236 loader to the bottom front of the tractor? Do you have a front mounted pump on that tractor for the loader? That is a very nice looking loader, did it come with the 265? I am looking at mounting a 236 on my 275 tractor, and was a bit hung up on how to plumb the hydraulic lines to the remote. The loader has control valves.
I have the loader and brackets, I am wondering about hooking into one of the remotes on the back of the tractor, or is there a way to put a divertor valve on, or how do I lock the remote in the on position to run the loader?
The loader is going to work painfully slow if you run it off the pump the 3 point, its only a 4.5 gpm pump. The front mount pump for a fel is in the 14 - 21 gpm range.
Dale, sorry for delay, but this 265 has
front mounted pump, loader works fast close
to modern tractor . The 236 loader came with
it. I am 2nd owner for few years now
