Trying to make hydraulic lift cover adjustments.
I have equivalent spacings for the ram arm, and dashpot
plunger. Quadrants are adjusted as seen in pics.
Manual says to loosen position adjusting screw just enough to
loosen control cam lever. Picture in manual points past the
draft adjusting bolt. Not sure what the position adjusting
screw is. Is it the same as the draft adjustment bolt? There is
a nut on the end of the vertical lever that does not seem to do
anything. What does it mean to free position control cam?
