New fuel gauge MF40
Jaypat88
Need help in how to wire new fuel gauge on my MF40. Can
someone explain what wires go to each terminal?
Thank you
There should have been an instruction sheet in the box explaining the terminals. If not try the manufacturers web site.
One should be battery, one lights, one ground and one to the sending unit. The one in the boot is most likely the one to the tank but depends.
Correction... the one under the boot should be the bulb. The one on the right looks to be ground based on the symbol. Lower left is battery and upper left is tank.
Again verify with the instruction or vendor web site. They can be different from manufacturer to manufacturer... (disclaimer)
