repower an massy 85
Yes, will bolt right in. Need the Perkins flywheel though from a Super 90, then the 85 clutch assembly will work. May need to rework one front block bolt or stud on each side too if my memory is right. One more change is the top left transmission front will need surgery to clear the diesel starter if I recall. The diesel transmission is different from the gas trans in that area.
