Cueballtech
Ok, bought tractor with bad clutch. Replaced clutch, did rear main seal while I had tractor split... Old clutch was soaked in oil.
Put new seals in, followed directions..
Did not trim was able to work both halves completely into the grooves leaving them very slightly "proud" so that they bolted together completely flush... Reassemble and fired up
Drip drip drip, WTF!!
Gonna put in new oil pan gasket now before I split this damn thing again. The plugs on the back of block were clean no oil... I'm at a loss.
