I am attempting to rebuild my lift cover and I am stuck at the point of piloting the cam fingers into their respective cams with the control quadrant is already installed? Manual says to remove rear bolt on mounting bracket and loosen the front bolt. How do I know if the fingers are in the cams correctly and how would I tighten mounting bracket bolt once lift lever is installed?
Also I have a replacement spring for the draft position control arm I need help in how to install.
Thank you
Thank you
