Cormiers Cove
My MF 35 has the old wing brackets that are used in conjunction with the headlights mounted on the side panels.
Can I still use the old wing style bracket with newer aftermarket headlights?
The aftermarket lights all have another piece that sits flush with the side panel and accommodates the ball of the new headlight housing instead of using the wing brackets.
Can that other piece on the aftermarket headlight housing be removed and the old wing style bracket used?
Also do all the aftermarket lights have low and high beam? My headlights did not have high beams. I already replaced the light switch with a new older style one and it does not have a high beam position. It only has off and 2 other positions. One is used for a rotating caution light mounted to the roll bar and the other is for the headlights and caution light together.
Any input is much appreciated
Thanks
Scott
Thanks
Scott
