Replacing Massey 135 front tires and rims - need advice.
Massey135
New User
Just bought two new 6.50 -16" 6 ply tires locally. Need rims now. I want same 6 lug 4 weight holes presently on tractor. This hole configuration seems standard for the front wheels on these older tractors. Old rims are dented. Is there anything I need to know before ordering these (2) rims - to avoid having to exchange via mail? Also, I will be putting ring weights on the "inside" of the wheels (45 lbs each). Ideas, advice suggestions appreciated.
That wheel is fairly common, I know some of the 1000 series tractors used the wheel (same lug pattern). The front wheels MF part number 506020M91 (4.50x16 wheel, the most common wheel), or 511611M91 (5.50x16 wheel, 7.50x16 tire). Those two wheels should have the 4 holes in them for wheel weights.
