Dieseltech?
Brown Swiss
Hey I got into looking in the gear cover on my 2745 and I found a roller lodged under the idler gear, roller looks to be from a bearing, it is around 1 1/4" long by 7/16" thick. The injector pump is a CAV inline if that helps, and also no hyd pump on the motor, later model. I looked in Agco parts and they only mention bushings not bearings, where did this come from? Hope you can help! Thanks
Never mind on it, lift pump push rod is what it was. Had a guy work on the injectors years ago and he took the lift pump off and mounted an electric pump, and apparently didn't take the push rod out.
