CES
Hi, Looking to order parts for this tractor. The dash has been replaced, no model/sn plate. Anything I can look for to identify what model it is? Has a 200 loader and a gas engine. Also has the right foot pedal directional pedal. Says acc on it (throttle).
Sounds like it may be a 204 or 205 industrial with the reverse-o-matic transmission. Does it have a 3 cylinder diesel engine or a 4 cylinder gas? Possibly a later industrial model.
If you could post a picture, or two it would be easier to tell what it is. Many models of MF tractors had a 4 cylinder gas Continental engine.
Some pics to help.
I thought the same until I purchased a tune up kit for a screw mounted dist. cap. The spark plug threads were too big.
Look on the left side of the engine. There should be an ID plate that tells you it's a Z134 Continental and the serial number of the engine.
