Iceman214406
Hey all,
Found a problem last week with Bessy (that's her name) where fuel was not entering into the sediment bowl. Luckily,
Tractor Supply Co. sells sediment bowls for Massey Ferguson which was compatible with Massey Harris. Fuel now
flows to the carburetor, but I cannot get her to turn over unless I use starting fluid. She will stay running as long as I
keep spraying starting fluid in the carb. Not sure if I should replace the carburetor at this point, or rebuild it. Any advice
would be greatly appreciated. For images, please go to http://s345.photobucket.com/user/iceman214406/library/
