shinnyboots65
good morning gentlemen I have a 60ish Massey Ferguson 150 tractor with a z-145 engine I have installed a loader on this tractor after much fab work on building a sub- frame to fit this creature the hydraulics on the Massey are to weak to run the loader so I'm wanting to install a front hydraulic pump on here to carry the loader and let the factory hyd. carry the three point hitch now my problem is finding the crank shaft pulley, shaft and pump I've looked on line and read a dozen forums and they tell me this can be done but I can find no numbers on the parts for the crank shaft pulley ,adapter plate, shaft or pump any thing ya'll can tell me would be a great help also will I need separate hydraulic tank to carry the loader/ thanks in advance
