Valve Seals
Does a 230 Perkins diesel have valve seals? The reason I ask is the gasket set I got from the MF dealer has 3 rubber valve seals in it but I pulled out a valve and there's not one. Just wanted to make sure before I put everything back together. Thanks.
The Perkins 3.152 gas engine should use them on the intake valves. Keeps oil from being sucked into the engine when you close the throttle on a gas, a diesel doesn't have that problem. Most gasket kits these days have extra gaskets, etc in them that may not be used so they don't have to keep two, or more different gasket kits in stock for the same basic engine.
