Grandfatherjim
This tractor has a FEL which I think is a model 100, and a Perkins 3 cylinder diesel. The frame of the loader gets in the way of working on some things, including topping up the engine oil.
The battery's not charging (hasn't been since I bought it) but being diesel I only need it for starting so just have been charging it up occasionally. I'd like to get the system working properly though.
I bought the service manual - which has so electrical section. However I also have a '58 TO-35 and expect it will be similar enough that I can figure it out.
Question is - where is the correct place for the regulator to be mounted? It is presently kind of hanging off the right side in an awkward spot near the loader frame that must be wrong.
Also - anyone know if the regulator is the same as the 35? That would be handy as I have a spare already.
Thanks.
Thanks.
