MF135 connecting rod order
Kalamazoo
I forgot to write down the direction and order of the connecting rod position numbers, and it's not in my service manual.
Perkins gas.
Thanks for any help in advance.
The rods should be numbered on the side 1, 2, or 3 where the rod bolts are. The numbers go towards the side of the block where the oil filter is, according to the MF shop manual.
(quoted from post at 20:27:02 02/17/17) The rods should be numbered on the side 1, 2, or 3 where the rod bolts are. The numbers go towards the side of the block where the oil filter is, according to the MF shop manual.
Is 1 at the steering wheel or radiator?
