Massey 1130
Farmall49
I had this tractor given to me by a friend a Massey 1130 and I was wondering how much it is worth it has a cab with an Ac that dose not work all the glass is good and the its in OK shape it a really nice front end loader maybe 20 years old with bucket and with a grapel brand new ruber all the way around is in good shape needs a pto clutch right brake and motor rebuild runs great has a new clutch to I want to fix it but kind of want to sell it and buy a allis charmers 7020 with power shift and low hours what do you guys suggest
i think I am with you guys now it had not started in 6 years put new baderies and turd the key a fired right away and ran good he told me it was a good tractor just he did not need I will use it to run a stack wagon and plow with 4 bottom roll over plow and disk and bale hay with two string baler and chop al lot of feed thouands of bushels of barley spread straw and haul 4x4 straw and hay bales with the loader thanks for info
I,ve had a lot of different tractor makes over the years but I would pick a MF over any of the others if I had a choice.
You will be able to pull a four bottom in road gear. Guy in town put a turbo on his 4020, because he was tired of his neighbor pulling a 8x16, twice as fast as he could pull a 4X16. With a capped fuel return line, it should run about 145 hp.
