44 special hydraulic cylinder
I have a 44 Special & I was wondering if someone could point out to me where the valve is located on the cylinder that bypasses the cylinder & just works the hydraulics I want to raise my 3 point arms but its on bypass Picture of it would be great The special has a different cylinder than the 44 & 444 Thanks Chris
Mine has a screw on the left rear side of the cylinder, behind a small cover that you turn off. This diverts the flow of oil, all to the cylinder , or all to the remote outlets, depending on the direction it's turned. Might be seized like mine is. Diverter valve. Ben
Does this have a nut with a standard like screw inside of it Can you send me a picture of it It looks to me like its on the back side of cylinder if that is correct Thanks Chris
