Ok so i decided to go ahead and pop the motor off the transmission since its the only thing left on there at the moment. Good thing i did. Clutch is soaked with oil and the main disk is broken. Thought it was rear main or pan seal since it seemed black. Turns out input seals on tranny are leaking as well as the pan seal. Figures... The throwout bearing is also grinding and the clutch fingers are well worn. New clutch time.
Looking at the parts diagram it looks like the seals are 195501M1 and 195503M1 with gasket 180434M1. Will that shaft assembly slide out the front? If not what is the suggested method to replace the seals? Any gotcha's?
