MF 40 lift bushing and spacer set
Jaypat88
Hello, I am looking for a bushing and spacer kit for my lift shaft.
When I look up parts I don't seem to get the right size bushings.
Thank you
Not sure what you mean by spacers.. The old style two bushings per side has been replace with one large bushing per side.
You can either use the bushings per side, part number 897574M2 you will need 4 of these. You can also use the 1 piece bushings part number 886029M1 you will need 2 of these. Now on the spacers on the outside (part number 366765X1) I believe those are used if lift arms are not on the tractor to protect the splines on the rock shaft from any damage, and keep any dirt, or water out of the lift cover.
