Ok I just got my uncles 1960 MF 65 with multi power and all fluids were low so I decided to just change them all because I had know idea what he was using before he died. I put the recommended 90 weigh mineral oil back in the transmission and pto. Replaced inspection cover seals and buttoned it up. I fired up tractor and engaged pto and disengaged it a couple of times also making sure live pto was correctly working. Today I returned to check all fluids and all were ok and I finally got it out and pressure washed all the old grease and oil off the engine and after I was done was going to bush hog a few minutes to check everything. Well the pto handle will not budge. It's like it's stuck or something. I drained the oil again and looked around in the case nothing looks bad. I did find several little pieces in the bottom that are about the size of a pencil lead and pointed on each end . Any ideas on what the problem is?[/img]
