Hello all
Thank you for your responses on this issue
Now Part 2
After further reading, I can offer the following
Super tractor SAE 15W-40 is a multifunctional fluid of the super tractor oil universal (STOU)type that is intended for use in both engines and transmission compartments of agricultural tractors and related equipment, including those with oil ?immersed brakes.
Your advice after this additional information would be appreciated
Regards
Don
After replacing the filter on the hydraulic pump, I intend to change the final drive & gearbox oils.
Has any one used or heard of ....Caltex Super Tractor oil.... According to the literature it is CF,CF-4/SF..GL-4...TE-ML06B...TE-ML07B...CMS M1144. The SAE grade is 75W-90.
Will this OIL be suitable for the old girl????
Thanks for your time Don
Now Part 2
Regards
Don
