Hello,
everyone I Aim working on a 1978 Massey feguson 230 gas with continetal z145 motor and would like to set up front mount hydraulics to run the front loader.Has anyone installed the hydraulic plate adapter that mounts onto the crank pulley. I notice there is very little clearance between the crank pulley and the axle crattle. I thought I would try grinding material away on the back side of the axle crattle for clearance. I dont want to unbolt the front axle and pull it forward just to get the hydraulic plate adapter bolted to the crank shaft pully . Does anyone have a good method for installing the hydraulic plate adapter ? nathan
