Finished the 135 with 3 cyl Perkins overhaul and tried to start it yesterday. Fuel tank did not have a shutoff so I added a new shutoff valve. Put 5 gal in tank, figured that's enough to start it. Got fuel to the lift pump and finally to the fuel filter. Started to see some at the injectors. Cranked it over and it wanted to star but only ran for half a min. I'm not sure the little lift pump is working. I pulled it down the road to try and. Get it started but it never fired. Took the little pump off and took it apart. It had some junk in it so ai cleaned it up and put it back together. Had trouble with the fuel lines going into the pump and the inlet fitting broke on me. I ordered a new pump so now I will have to wait a few days. Dick
