Recently purchased MF35 had been sitting for sometime
Has a grader style blade with it got it running graded a drive way
Changed oils cleaned hydraulic filter
Was running great starts really well
Did get a bounce out of the lift arms when reversing
Couple of days ago freed up the alloy adjusting knobs
On draft control levers and then moved them back and forth to free up the levers action, with out the tractor
running.
Next morning when I started the tractor there was a loud
Bang, no hydraulics and unable to select low ratio
Removed top cover and 1/2" lifting cylinder studs 2 broken and two are bent, control levers not in cams as cylinder had moved.
My question is could the internal levers
Have moved out of the
Cams by me just moving both back and
Forth to free them
Intend to make new 1/2" studs fit new orings and gaskets
Adjust internal controls and top link
Fit new relief valve.
Used 15/40 engine oil in engine and trans, the tractor worked fine like that, intill freed up the draft levers, which
I moved back to approximately the original postions before
Starting
Thanks in advance Bruce
running.
Forth to free them
Starting
