Bernard W.
New User
I want to rig up a test pump to supply pressure to the multipower clutch pack on a 50 Massey. My thoughts are to disconnect existing pump and then plumb directly into the selector valve in the bell housing. I do not know what pressure and GPM would be needed. Can someone help with this? I believe the selector valve in the bellhousing has a built in relief to maintain proper pressure. Is this correct? Thinking of using a 12 volt dc pump for this but need to know pressure and gpm required. Any reason this won't work?
Thanks for any help.
