135 transmission gasket removal
Ncnative
1973 MF 135 Perkins Gas (non-IPTO)
How to I get the transmission filter out so I can clean it???
I have searched the internet with no luck, some say there is a wing nut on top of the filter housing, mine does not have one. Some say unscrew the top by turning counter-clockwise, I cannot get mine to turn? all I can see on the top of my filter housing in the small metal bar/rod that the wire was attached to (I got the wire off in one piece). All I currently have is the IT manual, I have a repair and owners manual on order.
If the link will work this is what mine looks like.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=121975
(quoted from post at 11:35:30 01/19/17) 1973 MF 135 Perkins Gas (non-IPTO)
Sorry this link above is not how mine looks but the forum will not allow me to edit??? I cannot find a link to an image that looks like mine. Mine has a small (maybe 1/16" dia) rod that running across the top of the filter housing the the safety wire was attached to.
The top of the filter housing should have a metal tab like this
It's possible someone broke the tab off, and welded the 1/16" diameter rod on it.
If it hasn't been changed in awhile, or had water sitting in it high enough to get to the threads on the bottom, it can be a bear to get loosened up. Like pockypg said turn it "lefty loosy" (or counter clockwise).
(quoted from post at 12:06:28 01/19/17) The top of the filter housing should have a metal tab like this
Mine definitely does not look like this one. Mine has no tab. nothing on top of the filter housing but that small rob which I fear will break if I twist it very hard.. I tried getting an oil filter wrench on it I could get it on but no room to turn the wrench
The top piece has like a 1/4" bolt welded to it that goes down, and screws into the pump base to hold it on, but it shouldn't/doesn't need to be that tight as yours is.
see if this helps, credit to the late Great Big Dean -
<a href="http://s33.photobucket.com/user/Joecdeere/media/zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz0001_zpssdtv5m1u.jpg.html" target="_blank">
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz0001_zpssdtv5m1u.jpg" border="0" alt=" photo zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz0001_zpssdtv5m1u.jpg
</a>
(quoted from post at 20:46:17 01/19/17) The top piece has like a 1/4" bolt welded to it that goes down, and screws into the pump base to hold it on, but it shouldn't/doesn't need to be that tight as yours is.
So do I just get a hold of the top metal housing and unscrew it?
(quoted from post at 21:39:25 01/19/17) see if this helps, credit to the late Great Big Dean -
&lt;a href="http://s33.photobucket.com/user/Joecdeere/media/zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz0001_zpssdtv5m1u.jpg.html" target="_blank"&gt;
&lt;/a&gt;
Yes, mine is like the "new" one, so does the top just unscrew? (As you will see I have also asked ptfarmet if it just unscrews)
(quoted from post at 13:40:29 01/20/17)
(quoted from post at 12:46:44 01/20/17) Yup it just unscrews. You might have to lean into it but it will come out.
X2^^^^^^^^^^^^^^^^^^^^^^
Ok thanks I'll try to lean on it harder. Not a lot of room in there to lean!
(quoted from post at 18:29:51 01/20/17)
Fabricated a simple tool today and was able to use it to break the filter loose. If I knew how I would post a photo here??? The "tool" is basically two pieces of 1" x 1/4" x 1/2" steel welded together with a space between them just wide enough to fit over the "wire" that's on top of the filter housing. Then I welded a 1/2" nut on top so I could get a socket on it. ( I tied a string to my "tool" just in case I dropped it into the tractor bowels.) I was able to use a 1/4" drive ratchet with a short extension to turn it. I think the are also some "over-the-counter" filter wrenches that tighten up as you turn them with a ratchet would work.
(quoted from post at 19:30:21 01/22/17) Finger tight so its not loose, and use the tie wire. You shouldn't have to use any tools to loosen (or tighten) the strainer.
Will do. Thanks
