idle speed MF50 gas
Hay hay hay
I am sure this has been asked many times..but
The idles speed on my MF50 is too high...probably 1000 RPM...tach is broke.
The tractor runs great, just idles too fast.
How do I drop the RPM's? Is it the carb or the governor or the linkage?
And that idle screw must be behind the carb and under the heat shield, easy to see and reach?
Will I need to be a contortionist?
(quoted from post at 19:20:24 01/15/17) And that idle screw must be behind the carb and under the heat shield, easy to see and reach? Will I need to be a contortionist?
Should be a wing nut, and kind of easy to see. Sort of. You can also get your fingers burned adjusting it.
