1986 mf 30e seems to die shortly after giving it a load to pull and level with the gannon / box blade. The loader bucket doesn't do the same and it seems to idle indefinitely. Once it dies it won't restart. Turns over but won't start until I give it a freshly-charged battery.
I haven't done the full alternator diagnosis stuff quite yet. I intend to. Also the fuel injection manifold? leaks a bit just before it splits to the three injectors. Could it be sucking air in under load then dying? But then why would it not restart until a fresh battery is installed?
Confused and needing ideas.
