Re: Massey 50 Hydraulics
DavidP, South W
01-01-2017 04:01:26
Ho. to add a lottle to what Dieseltech has said;
You can slacken the four nuts on the top of the cover but do not attempt to remove the cylinder without first removing the hydraulic cover. Yes, the relief may have seized in the closed position but it could also be due to the fact that someone has re-adjusted or removed the Position Control lever stop screw on the quadrant. At the top end of the slot there should be a 1/4" unf screw and nut with a thick flat washer on it for the lever to make contact with. These screws are removed or adjusted incorrectly to gain more height on the three-point linkage. The result of this is that the ram arm makes contact with the casing and pushes against it with full pressure. Either the casing will eventually break or the cylinder will try to break free from the cover. The adjustments MUST be carried out correctly to ensure that the system is placed in neutral before 'lock-up' occurs. This is done by setting the stop screw. When correctly set you should be able to lift by hand the lower lift arms a further one to one and a half inches when fully raised by the hydraulic system. You may have wear in the 3-point which is another issue that should be corrected.
Let us know how you get on.
DavidP, South Wales
