V belt for MH 55
vnllgrll62
New User
Having trouble trying to find a belt for my MH 55, ser# gsw1101. It's a gas continental motor with one inch wide pulleys. Is there a set of pulleys to switch it over to a modern belt setup?
Try taking the belt into napa or one of the others. They should be able to look up a replacement based on existing dimensions.
You can get away with a narrower belt if there are no "correct" police around. Just
make sure it is driving on the sides of the pulleys and not bottoming out. Ben
The 1" wide v-belt should be M-H part number 35644A, you mat want to look for companies near you that sell industrial v-belts. If you have the old belt they can measure they maybe able to find one that will work, If you can give them the pulley diameters, and the center to center measurements of the pulleys that may help also.
Descripition
Brand:MASSEY FERGUSONPart Number(s):35644A ProductName:AUTOMOTIVE V-BELT
Cross Interchange Parts
NAPA 161
NAPA 161H
CHRYSLER B32517A
GM 2103345
GOODRICH 154
THERMOID V100
Cross over numbers might help your search or phone calls.
