MF275 STEERING PROBLEM
JDMAN60
I have a 275 that requires constant steering correction and I have to keep working the steering wheel to the right to stay straight. driving a straight line I turn the wheel left then back to the right a little more each time. it makes planting a real pain. Is this more likely in the cylinders or the steering motor on the end of the steering column? Thank you Willy
I had a 40b (industrial 245 or 255, don't
remember) that did that. Had 2 steering
cylinders. They had external leaks, so I
started there. That fixed it.
