Can anyone identify this my?
Olliejunkie
Sorry its not a good pic. I can get more.
It was supposed to say identify this mh but as usual spell checker fixed it and I didn't catch it. The John Deere is a B. I can't find any numbers on the MH.
Thanks for the help so far.
If you look on top of the transmission case to the left of the shifter there should be some numbers and letters stamped into it!!! First group will be model like 22GR then the serial number!!!
(quoted from post at 12:23:28 12/27/16) If you look on top of the transmission case to the left of the shifter there should be some numbers and letters stamped into it!!! First group will be model like 22GR then the serial number!!!
All I can see is a casting number. I forgot what it was now but I think it had a 6333 in it. I may have to take a bracket off and scrape some paint. There is no tag on the frame. It has been welded where it might have been.
