Front weights F-40
RedMF40
Hello
Anyone know of bolt-on front weights for my F40, same as MF50? Front end a little light even with full-size loader and 5' bucket. Thanks for any suggestions--and Merry Christmas!
If you can find front rim weights, the halves, that bolt to the inside, they would put on almost a couple hundred, and if a tire shop can 'foam fill' the fronts, that would add another 100 odd pounds, both without hanging more obsticles on the front end. Funny a loader tractor is light in the front. Might be something else going on.
Thanks, Tony--/yes, I added abt 900 lbs to carry-all
on the back. Needed the weight help me climb
some small hills around my place. As a result the
front needs more weight but not much. As you know
the loader is very heavy so that helps keep wheels
on the ground. Just getting a little unfersteer from
time to time. Thanks for the suggestion, will look to
see what's available.
