152 Perkins Need to pull sleeves
dacaseguy
Any suggestions on pulling pulling the dry sleeves. Crank is still in engine. Doing an I frame. I have a puller I used on a Case with wet sleeve that is within .010 of same size. I need to turn it down a little and it should fit. Dick
Yes take a welding jacket and put it over the crank and with a 110 mig welder run three or four beads in the sleeve and that will help shrink the sleeve down so you can pull them out much easier. Just remember to cover the crank if you can have someone hold that puller in the hole so nothing can get past
IN the archives ..Type in...How to Remove Sleeves on 3 cyl Perkins...
There are some dimensions and other info that you may be interested in...
Bob..
when welding the sleeves we usually put the rods back on and let them hang down and then cover it with something just to make sure the journals don't get anything on em. Good luck with old girl!
Thanks for the info. I was able to get one sleeve out today. I modified a puller I had to fit the sleeves. I'll work on the other two tomorrow. Had to cook turkey today. Dick
there is s a seller on ebay that will make a puck to fit your sleeve think he charged me $25 bucks. He made one for my mf285.
