As I pulled the #4 cylinder liner on my 285 last night I noticed residual coolant in the block dripping from the cylinder. There is a hole in the block that appears to be from corrosion. I was not loosing coolant while using the tractor. I am doing a rebuild due to low compression. I am pretty sure the block cannot be saved but there are a lot of you out there that know more than me. Is there anything I can do to save the block?
On a side note, I rigged up a puller using a bottle jack that worked excellent. Didn't take more than an hour to pull all four liners. A 1 1/4" pipe flange fits perfectly as a puck.
Doug
(IFF)
Doug
(IFF)
