I am working on a MF150 for my father in law. The front end goes into a "death wobble" while driving with much speed. The tie rods seem to be fine, and tires are 80%. From what we can see there seems to be slop in the pedestal shaft and controls arms attach. You can get side to side play in the arms on the shaft when you pry lightly against them. Is it likely that the bushings could be worn?
Also has anyone removed one of the pedestals? I have everything unbolted , but the thing will not budge at all. My guess is the shoulder on the bottom of the pedestal is seized into the hole in the frame.
