When I got my 135 a few months back the 3 point seemed to work fine and lift anything I put on it. Now it won't lift a grading blade I put on it. Checked the dipstick and no fluid on it. It hasn't left a drop of oil on the black top where I parked it. Can it leak internally, where I wouldn't see it. Maybe it was always low and I didn't really put any weight on it. Heading over to TSC to get fluid. Not knowing what's in it, what should I get? The little bit on the stick is very clean/almost clear, not dirty or black. I asked a question earlier about the valve on a remote. The valve will turn 360 degrees. It looks like a ball valve that is off when straight up or straight down, and on when straight forward or back. There is no detent one way or the other. While I'm asking, does the response valve determine how fast the 3 point lifts? I'm going to see if TSC has a cheap manual to answer the easy questions. Thanks Joe.
what position should this valve be in? I was told if it was run in the wrong position the 3 point wouldn't work.
This is the Woods 6' bush hog I got for it for $150. The friend I bought it from said he ran a 6' Woods on it and it didn't even know it was there.
I put new hitch pins in the lower hole because the previous owner blew the middle holes out with bubble gum welds. Figured if I used the lower pins the arms wouldn't have to lift as high to get the mower up.
