mf135 ,z145 choke bracket mounting to carburetor issue
This is a MF 135,Continental Z145.4cyl Gas .
I just replaced my carburetor TSX882 for a TSX683. The problem I have is the Choke bracket that attaches to the carburetor wont line up (sits on valve shaft loosely and no hole to screw it secured,just a peg sticking up).The difference is the old carb. has a molded ring that the valve shaft is in and fits diameter of a hole in choke bracket and has a screw hole to secure choke bracket. My question is do I have the wrong carb. or is there a way to secure the choke bracket to get this rebuild in the field.Thanks in advance
(quoted from post at 23:48:03 12/02/16) This is a MF 135,Continental Z145.4cyl Gas .
Some carb's had an L bracket made out of 1/8" X 1/2" material that was anchored to one of the corner screws that held the carb together. You might try to fashion one up.
