Front and rear main seals on MF 1155......
MF rules
My front crank seal and rear crank seal is starting to drip oil so after 42 years I guess they are needing replaced......my question is to the front seal, how do you replace it......can u do this without having to drop pan and unbolt front end of tractor?
I know the back seal will require a split job......probably do a new clutch and rebuild multipower while I'm there before I repaint the ole girl!
Thanks
