MF 135 Sheet Metal
cstory
Been needing to replace hood and side panels on1965 MF 135, been looking it appears other model MF tractors used the same sheet metal or do my eyes deceive me? All help appreciated.
The MF135, and some of the MF industrial tractors like the MF20, and the MF2135 use the same sheet metal. The bigger tractors like the 150, 165, 175, etc and up has the same styling as the 135, but the sheet metal is bigger so it won't bolt on the 135.
The 3 cylinder and 4 cylinder tractors have different hoods. The hinge is on opposite sides. Left for 4 cyl. and right for 3 cyl. The hinge
is on the opposite side from the exhaust.
If you are needing to get a new hood you need to get the hood, and side panels. The hood/side panels for the 4 cylinder gas that are hinged on the drivers left are no longer made. All the new hoods, and side panels are made to hinge on the drivers right hand side the hood/side panels used on the 3 cylinders. All the hood/side panels are all the same length, and width.
