1401815m1 shaft specs
Rkh
Got all the parts to put pump on crankshaft coming in the mail. Shaft 1401815m1 that
is being sent is not the original shaft- parts lady says it's similar. What is the
length of this shaft, diameter, and any other specs you can give me? This post is
added to the post below that I started a couple weeks ago.
Part number 1401815M1 is for the shaft, part number 1401814M91 is for the shaft, key, and coupler. Your shaft may include the key, and coupler. Some companies may sell the shaft, key, and coupler with the 1401815M1 shaft, some may not. The part number for the key is 1400303M1, and the coupler is part number 1400024M1. So you may want to check your order to see if you got the key, and coupler.
Got the adapter(704812m93),shaft (14 3/8 x7/8 with 3/4 keyed end, other end threaded to fit adapter). The shaft is not original part,according to Tips where I bought it, they said it would work- $50 vs $250. The shaft coupler is .680"dia on inside, but doesn't the hydraulic pump have a 3/4" shaft? The coupler doesn't fit 3/4" shaft. I got to thank ptfarmer for all your help.
Here's pictures
